Don't think so....
To access the diagnostics menu to review/change your CO settings:
Hold down both the SELECT and RESET buttons and then turn the key so the dash comes on and keep holding the buttons down until "DIAG" appears.
Press SELECT to display CO.
Hold down both the SELECT and RESET buttons again and "1" will appear.
Press SELECT and it will run through "1", "2" & then "3" for each cylinder.
On each of these hold down both buttons until 0 appears (this assumes your dealer hasn't changed the setting already) then use SELECT & RESET to increase or decrease the value.
Once finished on that cylinder press both buttons to save and continue and repeat for the others.
